Engine dies when I step on the gas
a 2-3 minute warm-up at the current ambient temperature is not nearly enough for a carburated car, especially if the choke is not set right. I shouldda mentioned that. So I would do the test again, but with a fully warmed up engine; the first test was relatively meaningless, except to point to a possibly faulty choke or choke adjustment..
I think there are plenty of relevant posts so far, that the solution is imminent, lol.
Most of the guys are pointing to the fuel system; and I agree.
But since the engine flat quits with no recovery, Ima thinking more along the lines of a load-induced ignition failure. Like a faulty coil or coil wire, or perhaps one or more faulty spark plugs. Or even a too-tight valve lash.
So if it was mine, I'd go back to the basics with a valve adjustment and compression test. Followed by assessing the timing and ignition system. If the timing is frozen at a very low number and Not advancing, this kind of thing will happen, because peak cylinder pressure will never occur at or near the optimum crank position, nor will it be very high, and the engine either misfires or just runs out of power very early. On a 6-banger this is very important, because there are only three ignition events per revolution, and they are 120* apart.
When you test the accelerator pump in the usual way, it may be just fine. But there is a second/third/fourth test for the A-pump; It has to begin spraying and not dribbling, at the slightest throttle-movement. And it has to do this from any point in it's travel, not just at idle. and as soon as the throttle stops moving, the spray also has to stop.
So say you come to that hill, at an rpm above stall, and with the throttle fixed at say 30% (I'm just guessing). Lets say the A-pump is 70% stroked out. When you begin the climb, the engine might run out of power and begin slowing. And so you increase the throttle to say 50%. Well when you do that, the pump better supply enough small-particle fuel, for the engine not to go momentarily lean. If it goes goes just a lil lean, then it may just hesitate then go. But if it goes very lean, it could misfire, and the engine suffers a 1/6th power loss. But if the misfired mixture is on fire and finds it's way back into the intake, now you have a pressure pulse in the intake!
When you get a missfire into the intake, all forward air-flow will stop, and the next several cylinders will get nothing until forward flow resumes. And if the pressure pulse went backwards thru the boosters, the mixture for the first few cylinders will be very rich.
At low rpm, the engine will just stall.
But if it doesn't stall, and you increase the throttle opening some more, it may be that the pump is fully stroked out, Now the assist has to come from the power-valve....... But with the near total loss of air movement in the intake... the engine is forced to try and stall, and at low rpm, only a heavy flywheel will prevent it.
IDK if this applies to your situation, but I thought it was worth mentioning, because it points to the importance of having a properly set up A-pump.
Another thing is to have a fully warmed up engine. The slanty is particularly sensitive to this on account of the long horizontal intake runners. On a cold engine, those runners will collect fuel on their surfaces, which will just hang out there until too heavy to stick anymore, then tear off move along. The choke is there to do two things; 1) to enrich the AFR to compensate for that fuel monkey business, and 2) to increase the rpm so the engine doesn't flood when the fuel tears off the cold walls.
In the meantime, there is a carb-heater right under the carb, whose job it is to get that plenum warm enough to evaporate the cold fuel, and put it back into the airstream. Later model carbs also have heated intake air to help with these same issues.
Somebody already mention some of these things, but they have to be collectively considered.
And finally, the coolant thermostat sets the minimum water temperature, and helps with setting the rate of warm up. If your cooling system is up to to snuff, I like to run it at around 200*F, as measured by an Infra-Red gun, on the hot-side of the stat housing. If yur running 160, good luck with trying to make that work. If all your systems are working correctly, you might get away with 185. But my slanty's have always run 195s.
Somebody mentioned the manifold heat control valve. This device does all it's work on a cold engine. If it has failed, then you lose the carb-heater, so that's a bad thing. Once the engine gets up to temp, this device is no longer useful, unless the ambient temp falls sufficiently to cause icing in the throttle bores, then you would really miss it if it wasn't there. Oh and just cuz the counterweight moves freely, does not mean that the valve inside the manifold is still there,lol. They can burn out. But maybe not on a slanty......
Anyway, it's lunchtime!/ gotta go
Thanks AJ for your insight. I tried to go up the hill with the engine (relatively) cold today because the car has never stalled when it was warmed up, only when cold. And the choke seems to work as it should, shut when cold and fully open when warm.
It very well could be some problem with the ignition system, it appears to be all original to the car, but my question is why would it only stall in "Drive"? when its in "Park" and I rev the engine, she revs up just fine without a hiccup.
Thank you for the info though, it will take some time for my noob brain to take it all in...
Like I said; Load-related.
This is very often an ignition problem, but could be low cylinder pressure, which could be one of maybe three reasons; design, age/wear, or tappet adjustment.
But the simplest and most common causes of all are; a misadjusted or faulty A-pump/A-pump circuit, or a too cold intake/engine. Either of which could be aggravated by a low intake vacuum reading, and retarded timing. A cold engine just makes diagnostics between very hard and impossible. A cold engine requires more horsepower to run, at a time where there is almost no horsepower being produced. This is another reason that the Idle-rpm has to be increased on a cold engine. And if the ignition timing-advance system has failed, that is a third strike against the cold engine.
The warmed up engine in Neutral/Park, will idle or can be adjusted to idle, on just about any timing, especially on a long stroker like the 225, cuz it has a lot of flywheel effect. And in fact, the warmed-up engine actually wants way more timing than the factory allows. Unfortunately, with a distributor timing system, the amount of timing at any other place but the Power-Timing, has to be reduced by the constraints of the system, and the ability of the engine to absorb it, without detonating. So if the timing between the Stall rpm and say 3600rpm has to be a slope with a certain gradient, and that gradient leads to an idle-timing of 5* After TDC, then that is what has to be.
But when you put it into gear, and the TC drags the rpm down, now a bad tune will make itself known because, the rpm can no longer free rev, which could have been hiding a multitude of tuning failures.
Tuning your slanty sortof parallels tuning a lawnmower. You could have that hummer working so fine in the garage, but it won't cut grass worth spit, when the blade slows down. There may be absolutely nothing physically wrong with that mower, and you might tear your hair out looking for the why of it. This is a load-related problem, and it's usually in the tune . But you gotta start with the basics to rule physical problems out.
That mower will start with as little as 30 psi compression. But it won't make spit for power on just 30psi. So that is why we start with a compression test. And this very often leads to a valve adjustment. And then unless it has an auto-decompressor, which thing I hate, you can tell what's what. Many push mowers with starter ropes, only make 90psi..... because you know, ladies can't pull-start them with much more than that. So if you get that push-mower to put out 90psi, you can bet there is nothing wrong with that part of it.
But hang on most push mowers have horizontal intakes just like the slanty, so you gotta prove that the piston is also sucking. And don't forget, the pushmower does not have a centrifugal timing advance system, so if she's down on power but has adequate cylinder pressure, then the next logical thing to check is the flywheel key, which sets the basic multi-purpose, all-inclusive, timing. And after that, you gotta check for a plugged muffler. and then the blades. Dull blades will drag the rpm down, just like the TC in your car. When the rpm drops, the two-circuit lawnmower carb gives up. It was not designed to run anywhere but idle and more or less wide open. And the governor sees to that. There is no A-pump, no power valve, no intermediate circuit, and sometimes there is not even a decent float chamber.So whoever is doing the tuning, has to get the settings just right.
The only basic difference between a push-mower and your slanty is five more cylinders and a level of sophistication that allows it to run under load at various other rpms than idle and WOT.
Ok it's getting white outside, so I better go install my studded tires.
Ok hang on, I thought I was talking to the OP, rivertaf .
But it seems you hijacked his thread, and I didn't notice. So, my apologies to rivertaf. and now I gotta make sure what I said still applies to DrillNFill.
Ok it looks like rivertaf is long gone and all my comments have been correctly targeted.
So, snowtires Here I come.
AJ and everyone, thanks for your replies, I really appreciate everyone taking the time to explain. I don't mind waiting to warm her up (in most circumstances). Its just one of those things that's kinda "irksome" I guess.
Is the choke pulloff working. It is suppose to partially open the choke once the engine start it is that little vacuum pod with the short vacuum hose on it.
To troubleshoot, you have to get out of the car sometimes... Just sayin'
Good Luck, Lefty71
Have you checked your carb float? If your running a Holley 1920 the float is made of a weird material that breaks down over time with gas. The carb could be sliding fuel in the bowl an pitching it back going up that hill. I know it sounds crazy but take a sec to look it saved me a lot of trouble.
