Thanks Junkyard. I’m gonna talk to him about just building the 360 now that we have it.
look, i don't know what the situation is but homie seems to just want to go against the grain and get a little different with it, which is
fine. i like different. different is cool.
but 360 crank in a 318 is just GOBS of money in machine work: cut the mains on the crank, skim down the counters, cut the rear main down to 318 size too. square and deck the block, align hone the mains. then cut it for whatever oversize. then pistons, whatever they wind up being are likely gonna need fly cut for valve clearance. and with all that, you're
probably looking at cutting the heads and the intake to get everybody lined up and happy. then you're into rods-- bolts & resizing, polishing the crank, balancing everything up.
just thinking about that undertaking makes my wallet hurt.
you have other, more viable options available to you that are much cheaper and more approachable: a 390 stroker for the 318 is different and neat. the 360 with heads and a cam would make 400+ all day easy money and not even break a sweat doing it.
