Engine Mounted Correctly?
domdart
Johnstown, PA
I just put a 340 into my 68 Dart tonite. The driver's side isolator and mount looks off a little. The passenger side centers up on the k frame nicely. What do you guys think? Thanks.
Ditto, put a level on it but make sure the car is level also or you will be off. BTW all Mopar motors are offset to the right (pass side)
Ditto again.
Get your level out top or botttom and suspect it will shift after the initial run in.
No big deal, just loosen the mounts and re-adjust.
I might be soon enough, without a tether.....
If you decide to shift it, it's best to loosen all the bolts holding the brackets to the engine, to prevent stressing the little rubber biscuits, in the long run.
340's were red in 68 only. Blue in 69, orange in 70 and 71, then blue again 72 and 73.
And the create engines were orange.
GREEN! ....... green? ...... GREEN ?????
About a 1/4" of slot showing on both sides. I shifted it around last night so both sides were equal.
