engine mounts identification help
72dustervs
Winchester, Kentucky
Need help to identify these mounts an one cross member before I decide to sell or keep , I believe there are some big block an small block , the transmission cross member does not fit my 72 duster , it seems to short maybe early a body I dunno ? , all these came with my car but I am going spool mount and I have the correct cross member so any help is appreciated
set above #1
set above #2
set above#3
The ones in the first few pictures look like Sweptline and Gen 1 truck mounts, later pics look to be B body, not sure on the crossmember- maybe F/M/J?
trans mount is 62/3 to 65. as the brake cable comes thru it. as said above, the 1st pics are truck mounts. measure the distance between bolt holes on same side and that will tell bb or sb eng.
