Jul 14, 2005 #1 7 75greenduster Well-Known Member Joined May 18, 2005 Messages 91 Reaction score 4 Location Norman, OK I'm swapping the 225 /6 in my duster for a 360. What should I do about motor mounts?
Jul 15, 2005 #2 ibleedmoparts Well-Known Member Joined May 10, 2005 Messages 799 Reaction score 20 Location Milton, Fl if i remember correct the 73-up should have spool type mounts...
Jul 15, 2005 #3 M moper Well-Known Member Joined Dec 27, 2004 Messages 15,912 Reaction score 2,541 Location eastern CT You need the Schumacher conversion mounts, unless you are planning to swap the K frame from a V-8 car. The mount on spool type combines the engine bracket, and the rubber isolator, so you need the entire thing form Schumacher.
