Engine mounts
69DARTS
69 Darts Rule
indiana
What engine mounts are these
Bought a truck load of 68 dart parts
Guy said they are 383 mounts he parted a 68 gts 20 years ago.
Black one is passenger side big block 66-72 B,C,E body. May work for A body. Other one is small block. Not sure which side as it could be A or BC,C,E body. Nothing special. Kim
Are the Schumacher mounts designed for standard SB V8 k member?
isn't the BB k frame different than the SB?
Their swap mounts are designed for SB or Slant 6 k frames, the reproduction mount that I referred to is a reproduction of the original factory BB mount, for use on the factory BB K frame..
