Yep...all good.You've checked and double checked? I'm asking because I made my living as a professional mechanic for a long time and I cannot count the number of times I "just knew" the firing order was right when it was not.
This ones a 72..Had it 4 years now and never driven it.. Hopefully soon.I love the car by the way. I had a '72 Demon... once upon a time![]()
Have not put a vacuum gauge on it.. All that blow by...could it be from something not so serious..?Can you at least tell us what engine this is? It has a tremendous amount of blowby. That could indicate rings not seating, a broken ring, cracked piston or some such. All of which could cause a skip. Are you 100% SURE the firing order is correct? I mean 100% and not 99. Have you put a vacuum gauge on it?
I pulled each plug at the cap.. some had no change, and some made noticeable change...unfortunately, I'm too much of a novice to understand the difference .The quickest and easiest and cheapest thing you can do is verify that the spark is doing its job. Pull the plugs and look for a culprit. Or like I said, pull the wires off one at a time and see how the engine responds. But, it could also be something like a split exhaust valve and it will do that. You could give it a compression test. All kinds of simple "shake-down" test that are free and easy.
It's also hard to tell, but the plug cables don't look like they're correct either, at the dizzy...but this phone doesn't have the best screen..Just haven't got around to that yet.. Was working through some electrical issues, so just have it running to troubleshoot.
Well, you could put a pcv valve on it and see if that calms it down.Have put a vacuum gauge on it.. All that blow by...could it be from something not so serious..?
I agree! They look out of order.It's also hard to tell, but the plug cables don't look like they're correct either, at the dizzy...but this phone doesn't have the best screen..
This ^^. Some had no change and some had noticeable change. There is your issue. Each cylinder working properly will change/lower the engines rpm's some when unplugged. A dead or misfiring cylinder will not, or not as much. Now, mark those that don't make a difference and see what's the problem. Faulty wires? Spark plugs? Bent distributor shaft causing the pickup to hit or gap too far?I pulled each plug at the cap.. some had no change, and some made noticeable change...unfortunately, I'm too much of a novice to understand the difference .
I double and triple checked, and then checked again... They're in correct order.. I wish it had been something that simple...and I guess now, I'm more concerned with the blow-by issue and what's causing that...unless it's connected in some way..Hard for me to see, but it looks as if your plug wires are wrong. Correct will be 1-8-4-3-6-5-7-2 clockwise on the cap. Driver side cylinders from front of car to back will be 1-3-5-7 and passenger side will be 2-4-6-8
Like the one here on the left
I'm not sure where You found that diagram panel, but it should be digitally run over by a cyber truck, & set on fire....lol.Hard for me to see, but it looks as if your plug wires are wrong. Correct will be 1-8-4-3-6-5-7-2 clockwise on the cap. Driver side cylinders from front of car to back will be 1-3-5-7 and passenger side will be 2-4-6-8
It's a 71 318 with "j" heads and 340 exhaust manifolds. I didn't put gaskets on, as I've read they're usually not needed and didn't come with them from factory. I bought the manifolds and exhaust from a guy that had it on his Demon.. He did have gaskets with it but I didn't use them. Can you reuse gaskets..? I bought some a long while back, but damn, they're really thick.What did you use for exhaust manifold gaskets? You can not use 340 gaskets on a 318. Or is the leak at the pipe? Your exhaust gaskets should be for a 273/318. Sometimes you have to go back to '66 or so for certain parts, the parts counter guys don't know that about 318's. Have had this issue several times when I rebuilt my 318. You have to know what you are looking for.
Will be doing that tonight.............
Will try setting a more advanced timing tomorrow...not surecof the cam specs, but seems pretty healthy. Compression test wasn't too encouraging.. 105 was lowest and the highest was 135.If it has any cam at all its going to want more than 10 deg. Try 12-16. If you pulled a wire and no change then its a dead or weak cylinder. Whats the age or story on the plug wires and plugs?
