engine sound clip
demon_408
walnut cove nc
well here it is ...sounds funny in my metal shop i got ..but oh well what the hell !!!!
It don't SOUND,no pun intended, like you will have any problems.
Sound's real good!! and it sure went good with my coffee this morning.
Thank's for sharing.
Did I see a SMILE, man that thing sounds good! Get it put back together so we can go racing.
well thanks for all the compliments .. and to you BJR Racing THANK YOU for the portwork on the eddy's and setting up the springs and just for everything!!!!!!!!!
Sounds very, very responsive! Excellent job. Have you posted your specs anywhere?
what is it you wanna know? here is my combo if that is what you ment.
ok here it is.... 408ci, 12.5 or a little more,scott brown solid roller,290-300 adv, 258-266 @050 lift is 638-630...lobe centerline is 108-116...lobe seperation is 112 degreed in at 106...eddy heads flow 298@600 int....212@600 0n the ex ...M1 intake...1050 dominator... 1 3/4 in headers.. has crane gold rockers thats about it
Thank you. I can't believe how relativley good that cam sounds at idle with that much duration. With 12.5:1 compression, I'm assuming that this is a race fuel only engine unless you are running E-85?
