Engine swap;D100. Teener out,slanty in
AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
South-Central Manitoba,Canada, 900ftelevation
OK my turn to ask questions.
I have this 80Volare rust bucket with the 225-904. And I have this nearly-a-rust-bucket 1984 p-up which had a teener-904. I have decided to make the old D a dump-runner. Just something to fire worthless stuff into all week, and then run it to the dump on Saturday morning. I have no interest in resurrecting the body on the old girl, but it has good running gear. So here's my question;
Will the slanty engine brackets from the '80 drop onto the 84 mounts?
Didn't think the Volare had removable brackets on the K member but if it does you could surely weld or adapt them. Otherwise the passenger side mount will be the biggest problem. They should both be spool type mounts though.
Car and truck mounts are different.
