I would not believe that if I hadn't seen it before. Back in the 80's a customer of mine raced a boss 302 ford tunnel ram engine and they were in the pits after a run and he left the fuel pump turned on and walked up to the stands. A while later he went to start the motor and boom, he said there was flaming oil all over everyone's car around his and his was on fire, then came the fire extinguisher white powder every where. The next week when I walked into his shop I seen the oil pan and 1 valve cover with all the bolt holes ripped out and he said he never found the other valve cover.
