engine weights 383 vs 318/360
Tinbasher
Alberta, Canada
Hi!
Does anyone know what a 383 with aluminum heads and intake
weighs compared to a small block with stock iron heads and cast iron intake? I am curious to know. Thanks.
There's about 120 pound difference between a 440 and a 360. If that helps.
Alum heads, intake will get you right about where the SB weigh.
383 about 620#
SB about 525-540
I can tell you this. I about had an effin' stroke back int he 70's when I put the sixpack back on my 70 once.
I just went through this, and with aluminum heads intake waterpump and mini starter its sb weight.
Thanks for the replies guys. Good information! I suspected they'd be close.
Have to start watching for parts for a future upgrade from my 318.
That old 6 pack intake was wacky heavy! Being cast iron steel! Yea! Whew! Huff N puff!!!
What is the weight savings on iron to aluminum for the BB head? 50lbs. A head? The intakes are a Tidy bit of weight as well. Swapping out the water pump and it's housing is a good weight move too.
I'm swapping out the intake on my 383 today, stock 383 4bbl cast to a Performer dual plane. I will throw them on the scale when i get it pulled off.
I think I got this off moparts a couple years ago. I think it's pretty accurate.
Quote:
400 block empty weight-222lbs
complete stock b motor short
block-350lbs
452 head 51 lbs/ea
stage 6 head 26
lbs/ea
difference of 25 lbs/ea
iron intake 40lbs
aluminum
intake 15lbs
iron ex. manifolds 50 lbs
headers 25 lbs
iron water pump/housing 20
lbs
aluminum, setup 5 lbs
difference of 15 lbs
Stock (all iron) Engine Weight's
Slant Six 475
273-340 "A" V8 525
360 "A" 550
361-383-400 V8 620
413-426W-440 V8 670
Street Hemi 765INDY MAXX AL engine - 528CI - 470 lbs assembled
I believe the 5.7 hemi is 475 lbs fully dressed...
Thanks for the info... Looks like that info is right on as far as the intake is concerned. I weighed mine in at 41.5lbs for the iron and 14.8 lbs on the Eddy Performer intake. The rest of mine is just the stock iron setup.
