Engine would not start
Roadart
Escalon ca.
Took the dart(318/904)out to check for leaks, fan fitment etc. Stopped at neighbors house(next door) to show it. After a few minutes ready to leave,no start. Had gas no spark . Pulled it home let it sit a couple hours cooled off started up no problem . Would the coil do that ?ballist resister? Ideas please. I plan on wraping the headers to lessen the underhood heat.
Have another coil but neg. screw is messed up. Will try a new one,felt it probably is coil!!
Did it quit while you were running it???
No....then it really shouldn't be the coil. Check under the distributor cap, bad/ corroded contacts , rotor. Cheap caps these days expand when hot, add some corrosion and it could be your issue.
