Found a good solution. I am ordering 15x8 rims and found different tires on storage at the local Pep Boys. They told me we can put on 2 tires on the new wheels and then test if I have space. That way I dont waste money buying the wrong tire. I will try first a 295/50-15 and if that doesnt fit I go with 275/60.
The 295 will not fit if you're lowered. Mine barely fit and I have the 1/2" spring offset and another 1/2" trimmed off the quarter lip. There's zero extra space, before I installed the 7/8" rear sway bar they would rub when I went over speed bumps or on driveway transitions (ie, with any significant body roll). It's not even worth trying if you're not raised up in the back and hanging them out of the quarters.
