Evans Coolant Temps
Why are you running a 16 pound cap? You don’t need it. I run a 2 pound cap.
If you are pushing coolant out, you have other issues. Evans doesn’t make or need pressure.
I know that without pressure you get cavitation, how much pressure do you need to keep it from happening ?
IDK. I’m not having issues and I run a 2 pound cap and it doesn’t really need that. I can take the cap off when the engine is up to temp and it’s just like when it’s cold.
I suspect the cavitation issue is overblown.
