Exhaust Advice
scatpakman
Osseo, MN
I'm looking for advice from you Dart owners. I've mini-tubbed and moved the leafs in board. I don't think I can run the exhaust in the stock location. Looking for pictures or suggestions. Thanks in advance.
If you moved the leaf springs, a stock kit is not going to fit. It's already a tight squeeze when they are in the stock position!. However, you should be able to get a good shop to cut a segment out or add a segment in to whatever tailpipes you choose to get them to fit.
I don't know about Darts; I'm only responding cuz you didn't say how far you moved the springs,lol.
But on my 68 Barracuda with stock tubs and relocated springs, with the offset kit; not into the frame rails; the TTI 3 inchers still squeaked in there, with the stock fueltank.
Yeah, I should've included more info. Moved the springs to the frame rails and narrowed the housing 3".
