Exhaust maniifold hits power steering gearbox
The Furnace
michigan
Im putting a 360 engine in a 76 dodge dart sport. The manifolds I had both exit in the center and the drivers side hits the power steering gear box. Im guessing I need a manifold that exits the rear. Anybody know the part # for that manifold or if there is on that can bought new and if so where. wasnt sure if a magnum manifold would work for an LA engine like off a dakota or something like that that would be available aftermarket. Any input would be greatly appreciated I'm sure Im not the only one that has run into this problem. Alsp it should be noted this is a S/6 conversion with conversion spool mounts.
Obviously...needs one that looks like this:
btw...its not for sale.
Treblig. He is DA MAN. He will hook you up. You have been told twice now.
