cuda guy
- Joined
- Oct 15, 2009
- Messages
- 492
- Reaction score
- 32
Hi everyone
I am rewiring a 1968 cuda with a 440 I seem to have figured out some of the wiring but when it comes to the alt wire I'm confused
My alt has 1 feed which I ran the green wire from the voltage regulator to the pin in the alt
The ez wire kit has a red wire called Alt from the fuse assembly where does that go ? do I run this to the lower post on the Alt or do I run a wire from that post to the starter relay to help recharge the system or do I rum it straight to the battery in the trunk ?
Long question
sorry
I did run the Alt ex white wire to the voltage regulator
I followed the 5 pin wiring diagram right to the letter 4 pin Ballast resister the works
Thanks
Long question
sorry
Thanks
