johnparts
Slammed 1
So would the spindle and calipers from a 78 Aspen work on an A-Body?
So if I get the spindles, rotors, calipers and the brake hose that goes to the caliper I should be able to bolt it all up in my car (70 Dart) once I get the correct upper control arms and master cylinder. One more question would all this same hardware work from a 77 Cordoba?
You need the 73-76 A body lower ball joints.
The earlier ball joints have a narrower spread of the attaching bolt holes.
Anybody at all know if there is a difference in the lower ball joint from a 70 Dart verses a 73 on up? And the spindles from a 85 Diplomat will they bolt right up or do I have to make any modifications?
