Factory colors in spray can...
Mopar Body and Trim
  1. Dartthunder340
    Dartthunder340 Well-Known Member
    1,978
    2699
    Sep 13, 2010
    Colorado Springs,Co
    Local Time:
    12:13 PM
    Who are you using, or had good luck with, for the aerosol spray factory colors? Thanks!
  2. krazykuda
    krazykuda Well-Known Member FABO Gold Member How-To Section Editor
    52,503
    17364
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    12:13 PM
  3. Demonic
    Demonic Well-Known Member
    1,169
    913
    Mar 21, 2015
    Maryland
    Local Time:
    1:13 PM
    I used the auto parts store spray paint as a base, then used the Mopar stuff as a top coat. The Mopar engine paint is notoriously thin.
    • Like Like x 1
    • Agree Agree x 1
    • abodyjoe
      abodyjoe Well-Known Member
      20,599
      5608
      May 22, 2004
      Berlin,N.J. 08009
      Local Time:
      1:13 PM
      i went to the local paint supply house and had them mix the color i wanted and put it in spray cans. for what i needed i used a single stage. they put a hardener in it . you break the blatter for the hardener, shake well and spray. it worked and held up great. they can also do base coat clear coat..
      • Like Like x 2
      • Agree Agree x 2
      • abodyjoe
        20,599
        5608
        May 22, 2004
        Berlin,N.J. 08009
        Local Time:
        1:13 PM
        • Like Like x 4
        • Fred Scigliano
          Fred Scigliano Lots of money
          13,440
          16981
          Nov 26, 2017
          NORTH DAKOTA
          Local Time:
          12:13 PM
          • Like Like x 2
          • Agree Agree x 1
          • DusTed74
            DusTed74 Well-Known Member
            916
            106
            Nov 12, 2006
            Oklahoma
            Local Time:
            12:13 PM
            My pal talked me into this. Man it helped.
            Ted.
            • Like Like x 4
            • Agree Agree x 1
            • Dartthunder340
              1,978
              2699
              Sep 13, 2010
              Colorado Springs,Co
              Local Time:
              12:13 PM
            • JoePole1
              JoePole1 A dude in a B body FABO Gold Member
              362
              315
              Mar 3, 2018
              Hudson Valley, NY. NOT NYC!!
              Local Time:
              1:13 PM
              Painted my engine compartment with auto paint supply mix same as Ted and Joe. You can control the spray fan by twisting the nozzle. Very happy with the results. Would also use in trunk, underside of hood and trunk or door jams but not on body.....but you could I guess.
            • Dartsun
              Dartsun Member
              1,190
              802
              Feb 12, 2012
              Springfield Oregon
              Local Time:
              10:13 AM
              I use the spray max brand for work in a gloss black. I’ve never used a better spray paint. Use it for painting hydraulic tubes it’s pricey but well worth it.
            • DusTed74
              916
              106
              Nov 12, 2006
              Oklahoma
              Local Time:
              12:13 PM
              Here's the paint for the steering and the torsion bars. It's Rust-Oleum Engine Enamel. The color is Cast Coat Aluminum.
              I hopes that it helps. Ted
              • Like Like x 1
              • VSTwister
                VSTwister Well-Known Member
                344
                61
                Apr 23, 2007
                Columbiana, Ohio
                Local Time:
                1:13 PM
                What my painter is using:
              • abodyjoe
                20,599
                5608
                May 22, 2004
                Berlin,N.J. 08009
                Local Time:
                1:13 PM
                You specify base/clear and they will give you a spray can of clear to go with the base.
                • Like Like x 1
                • VSTwister
                  344
                  61
                  Apr 23, 2007
                  Columbiana, Ohio
                  Local Time:
                  1:13 PM
                  Thanks. I deleted my question because I saw yours above (sorry I don't know much about auto paint) but makes sense you'd need a spray can of clear to top coat the base spray can paint.
