[SOLD] Factory Early 70’s 340 Intake
12many
SC
Part#3671918AE cast iron intake. All threads good, Carb and head surfaces good, thermostat/outlet surface has some pitting/corrosion but is minor. Did not leak (the gasket wasn’t slathered up with sealant to achieve leak free either) Needs cleaning and paint only. $90 +shipping or you pick up.
After a little closer inspection Found the date code!! 6-26-73 Still available
