Hey guys.
My factory tach on my 68 barracuda was not working, so I installed a new tach kit from Realtime Engineering, after installing the new tach board I tested the tach on my car, 12v to tach, - Neg on coil to tach and grounded the tach case ... started car up and the needle does not move..
When I push the tach needle up with my finger it stays stationary, not sure if that's normal or isn't supposed to spring back down to Read 0.. also I'm running mopar electronic ignition.
Thanks for any advice
