fan clutch or not
bmaudlin
Tucson, Az.
1970 Dodge Dart Swinger with the 340 engine without A/C. Does this car use a fan with fan clutch or does it use a direct drive fan with a spacer like my 69 Dart did? Any help would be appreciated! Ben.
..........No one has any idea whether the 70 340 engine had a fan clutch or blade only?? no A/C? Ben
I am almost sure that all 1970's used Non Thermal type clutch fans -very tough to find!
They are only 2 1/2 inches deep with the shaft.
..as Crate says 70 340 came w/ a non thermal clutch fan.
..the hayden is a short shaft jag unit and your fan will be too far from a stock rad.
..mopar have a quality replacement unit that is also thermal.(performance model)
..they typically spin at about 80% water pump speed and may run a tad warm on a hot day at the stop lights.
