Fan clutch question for a bigblock A body
dartcuda1
67 Barracuda 500ci 6sp
Malvern Pa
Has any put a clutch fan on a bigblock A body.If so can you tell me what part numbers for the clutch{if there,s any}. Mark
thanks longgone,do you have any pictures to see how close it comes to the radiator. Mark
Longgone is correct on the part number. Seems like I had about 1/2" of clearance (maybe less) with a stock style 22" 3-row rad and shroud. I ultimately took it off and went with a solid fan. For me, it cooled better.
Thanks 70Duster440 for the part# confirmation, and likewise I have maybe 1/2" clearance from the radiator but I do have an aftermarket HD radiator. You may have a bit more if you use a stock radiator.
Thanks you guys.I have both and I think I amgoing to use the aftermarket one.I am just not into electric fans.I like the less the better and thrugh the years the clutch fan worked just fine.Thanks again Mark
