[WANTED] Fan Shroud and Clutch Fork
pa karp
Ft Pierre
Rating - 0%
0   0   0
I am in need of a fan shroud and clutch fork for my 69 'Cuda 340 4 speed.
I need to add the windshield washer reservoir also.
Thanks
Pa karp
Pa, I have an original water bottle from my 69 downstairs. It needs a cap and it is not very white like new ones but it is not broken.
Tom
Washer bottle for power wash I have w/pump. Washer bottle for foot pump I don't have. I'm not sure which shroud would be correct for 69 340 . I'll guess ***-614.
If so the ***-037 for slant 6 will work if installed upside down.
PM sent.
Pa karp
I have found the clutch fork. probably have the washer bottle and shroud also.
Thanks for the replies.
Pa karp
By the way... The ***-614 shroud is reproduced. Those got a bad reputation about 6 years ago when first released because they melted LOL
We can assume that has been corrected today.
Unless you have already upgraded to the spool type fail safe motor supports..
I strongly suggest some sort of catch cable for the left side of the engine. Reason being,
When the left biscuit type motor support breaks, the fan eats the shroud. This was more common on manual trans builds too.
I will probably go the reproduction route on the fan shroud. Thanks for the tip on the motor mounts, forgot about that.
Pa karp
