There are several ways around this problem, depending on your igniton
You still running a ballast resistor?
If you are not, you should be able to wire the old brown, dark blue, ignition junction all together with the pink
If you do run a ballast, do one of the following:
(The problem of course, is that the "ignition run" goes cold during crank, so the only two hots are the brown bypass and the yellow start wire.
Hook the pink to "ignition run" which is cold in start, hot in run
1---Junction that point with the output of a bosch relay fired by the starter relay yellow wire
2---or just run a big diode from the yellow start wire on the relay to the junction of the pink/ run
You want the diode band (starter relay start wire) ----->|----- (pink and ignition run)
3---Replace the start relay with a later Jeep on which has an extra set of contacts you can use wire the extra contact right over to the pink/ igntion run junction
G, I, and the battery stud hook up as per your old one. "bal" goes you your pink, and the "egr/ sol" go to your starter solenoid as the old one. Youll have to install a heavy spade connector on that wire.
