LIME TWIST DART
I have this Helix tilt column that came with my project. I'm gonna describe what I'm thinking to do for install, but I'm looking for feedback and suggestions; other ways to go, options. I want to make sure that its properly secured and looks clean.
The column is a manual floor shift with a 2" tube and is about 32" in length. It will be mated to a Flaming River quick ratio box. This will be next to a 360 based 408 with TTI headers.
I plan to use a 2" swivel base through the firewall, possibly mounted to the factory bracket,(so the entire opening is covered). This is where I'm looking for some ideas. Anybody done something similar?
For under the dash I was looking at a couple different column drops/mounts from flaming river. Of course they ain't cheap. Using the half bracket will allow the column to sit up against the upper dash mount, but not sure how secure that would be compared to the full bracket. The full bracket would keep the column about 1/2" to 3/4" lower than the half bracket.
My plan was to install steering box, loosely mount the column, then adjust the depth with consideration to the added length created by wheel adapter and wheel. Lastly, mate the column with box based on the left over distance.
Any thoughts, feedback or links to other posts or threads are appreciated.
