Fender braces
Mopar Body and Trim
  1. ratvon
    ratvon Well-Known Member
    362
    42
    Aug 21, 2010
    central ohio
    Local Time:
    11:44 AM
    If anyone has pictures and dimensions on on lower front fender braces will you share them with me!
    I having issues with tire clearance on a 68 barracuda, I'm no expert, but I'm pretty sure that they didn't have them but if I could see how the darts were mounted I may use them!
    Thanks Rob
  2. Dragonsteel
    Dragonsteel Well-Known Member
    203
    229
    May 12, 2015
    Missouri
    Local Time:
    10:44 AM
    Here you go!
  3. kursplat
    kursplat FABO Gold Member FABO Gold Member
    3,355
    2241
    Aug 24, 2010
    so cal
    Local Time:
    8:44 AM
  4. 72bluNblu
    72bluNblu FABO Gold Member FABO Gold Member
    11,001
    5452
    Nov 28, 2008
    NorCal
    Local Time:
    8:44 AM
    I don’t have dimensions handy I can measure a set later. I extended mine about 2” if I recall correctly.
    They run from the front lower corner of the wheel opening to the bumper mount. On the fender side there’s just a hole in the bottom lip on the fender and that end of the brace is threaded. On the other end they use a U-nut clipped on the bumper mount.
    • Like Like x 1
    • ratvon
      362
      42
      Aug 21, 2010
      central ohio
      Local Time:
      11:44 AM
    • ratvon
      362
      42
      Aug 21, 2010
      central ohio
      Local Time:
      11:44 AM
      Yes that looks like what I need . Could you get me a couple pictures of both mounting points?
      Thank you very much
      Anyone out there have Set that's threaded ?
    • 72bluNblu
      11,001
      5452
      Nov 28, 2008
      NorCal
      Local Time:
      8:44 AM
      Sure, I can get a couple more pictures. I'll get the measurements I said I would too, sorry it slipped my mind
    • kursplat
      3,355
      2241
      Aug 24, 2010
      so cal
      Local Time:
      8:44 AM
      that's an interesting idea. never seen anyone do it that way, wouldn't be hard to make...
    • ratvon
      362
      42
      Aug 21, 2010
      central ohio
      Local Time:
      11:44 AM
      Where did you find threaded ones?
    • 72bluNblu
      11,001
      5452
      Nov 28, 2008
      NorCal
      Local Time:
      8:44 AM
      Not sure I understand. The threaded braces are stock. They came on every single one of my cars, which is 2x '71 Darts, 1x '74 Duster and 1x '74 Dart. I've also seen them on several A-bodies at the wrecking yards. I'm pretty sure the only '67-'76 A-body that didn't come with them was the Barracuda.
      The only thing I did to mine was lengthen them so that they push the lower front corner of the wheel opening out so my 275/35/18's didn't interfere. The stock braces are 12" end to end, mine are now 14". Here's the pictures...
      From the bottom
      From the top
      at the bumper bracket
      at the fender
    • ratvon
      362
      42
      Aug 21, 2010
      central ohio
      Local Time:
      11:44 AM
      Nice! Thanks for the information!
    • ratvon
      362
      42
      Aug 21, 2010
      central ohio
      Local Time:
      11:44 AM
      I misunderstood I thought your brace were adjustable
    • 72bluNblu
      11,001
      5452
      Nov 28, 2008
      NorCal
      Local Time:
      8:44 AM
      I may replace them with a set that is, but it really doesn't matter. I just measured how far out the fenders could go before they started to really distort the body lines of the fender and made the braces about that long.
    • zkx14
      zkx14 Duster De-ruster FABO Gold Member
      25,367
      20069
      Dec 23, 2012
      South Central PA
      Local Time:
      11:44 AM
      Normally, the adjustment is the slot at one end. I think I have a pair I'd sell. PM me if interested.
    • 72bluNblu
      11,001
      5452
      Nov 28, 2008
      NorCal
      Local Time:
      8:44 AM
      Yes, these are the stock and modified braces off of the car. There is little bit less than an inch of adjustability there. Mine still have that, so they have the same amount of adjustment as the originals did.
      • Like Like x 1
      • kursplat
        3,355
        2241
        Aug 24, 2010
        so cal
        Local Time:
        8:44 AM
        i took him the mean like tie rods...
        • Like Like x 1
        • 72bluNblu
          11,001
          5452
          Nov 28, 2008
          NorCal
          Local Time:
          8:44 AM
          I thought he was talking about the bolts threading into the fender end.
          At any rate, the pictures show the braces on my car. And other than being longer they function just like the stock ones do, because they're just lengthened stock parts.
