I updated it so it was easier to understand also I missed the console on the first pass.
hey Rocky.
Is there a specific black? Satin, gloss, flat? I have a pretty good parts store by me with a great paint department, would he be able to mix the correct paint from the tag???
Sorry to be a pain, but thanks.
Jim
In at least '67 and up metal dash frames, column, glove box are a textured black satin in. Rustoleum textured black works very well. Not sure in 65. Look in corner of dash frame unexposed, under dash pad, inside glove comparement box.
Upper door frames and lower frame under the door panel are gloss black.
Conv top mech is semi gloss black.
Codes should be in the factory repair manual I believe.
"Fender Tag".
Tag! You're it!
