Buy tires that fit.
That would be awesome, but not in the cards.
Is there anyway you could get me a few pics of the inside of your fenders after you made the so I could see how much lip you left? Also if you have any pics side view with the wheel in place. When you bent the fender in, what did you use. Thank you in advanceI bent mine in a bunch. But I think you could do the same but just a lesser amount.
does ur car have fender braces close to the problem area ? u could make a little longer braces that would shove the fender out some, for more clearance when turning.rolling them can easily cause damage yet you do need some lip for strength. My advice is to remove lip material and then be sure the remaining lip is smooth.
Thanks Bob, I went ahead and removed the lip from the bottom up about 4.5" then took 3/4" up to zero, like a pizza slice and they came out really nice. Looks like they were made that way.does ur car have fender braces close to the problem area ? u could make a little longer braces that would shove the fender out some, for more clearance when turning.
