killnine
So I replaced my old rotting fuel tank with a new spectra, and it just isn't right.
It's worked for me for a while now but it is sort of connected in a cockeyed fashion, and it's causing fuel to leak out of the grommet. Or the grommet is just wrong somehow.
When I installed it, I had a really hard time getting the neck into the grommet like most people. However, I also couldn't quite get the neck as far back as it should be. It is pushed forward towards the engine bay enough that the big rubber seal that it goes through is being pushed forward as well and you can tell that it's just wrong. I think this is deforming the grommet enough to make it leak. Of course after I got it in I certainly didn't want to redo it, but now I want to solve the problem. I'm thinking that possibly something is causing the tank to not sit as far back as it should. I put some tar paper in there like the original had, but I can't imagine it's so thick that it would cause an issue. Anyone have this problem? Any ideas before I just blindly tear it apart?
