Finally ! 2998325
Johnny Dart
So Cal
Finally got the highly sought after 2998325 fan shroud from a member (thanks Steve) today. Have been looking for one of these for awhile.
Cleaned it up,and shot it with some SEM black plastic dye,and installed it.
The cars has been running a little hot,so hopefully this will fix it.
Seems like much more air is pulling through the front of the rad.
You engine bay is too damn clean....throw some dirt and oil on it so I don't feel so bad. :angry7:
Please let me know how the SEM plastic dye holds up on the shroud. I just polished mine w/ back to black and am not really happy w/ the results.....Seems to look kinda gray. :cheers:
15* cooler is what I noticed after install.
Lol....Everytime you see my car you say the same thing.
I drive the shat out of this car. Just choose to keep it clean. 8)
Got this tip from a local Mopar guru.It is a die,so it wont flake.
It is what you use for your plastic interior parts as well.
Will do my best to keep you informed.
15* sounds gooood !
Thanks.
Nice Johnny. Did Phil give you that tip?
15* sounds gooood !
Thanks.
it will flake if the part isnt prepped properly.. but SEM dyes are the way to go. just redid the entire interior (plastic) of a 90 mustang and it turned out great! use light coats as well, johnny your shroud looks good, not trying to say it will flake just fyi for others.
