Finally checked my fender tag
michformulaS
Midland Michigan
Here's what came up. It's a fastback. How could I have upper door fram color? I am thinking this fender tag doesn't go with my car. The VIN is definitely a 68 340. What are the body belt moldings? From what I could tell and the original color on the inner fenders my car was Turbine Bronze 340 S. It still has power brakes but was the power steering stock? Do these come with a master cylinder with a 7/16" bolt holding down the cover like mine? I haven't seen any pictures with a master cylinder with this cover. September 26th seems like a pretty early build date for a 68 formula S. Is it? I still have a red line spare. I only have a 120 mph speedo and no woodgrain is this correct for a deluxe interior?
CAR: Plymouth Barracuda 2 Door Sports Hardtop
ENGINE: 340cid 4-bbl HP V8
TRANSMISSION: 3-Speed Automatic
TIRES: E70x14 Red Sidewall, steel belted
BUILD DATE: September 26.
AXLE: 3.23 Rear Axle Ratio
INTERIOR: Deluxe Trim Grade, Vinyl Bucket Seats. Black Interior.
PAINT: Monotone Bronze Metallic Paint.
OTHER: Black Upper Door Frame Color. Black Horizontal Sport Stripe.
MOLDINGS:
25: Drip Rail Mouldings
30: Body Belt Mouldings
78: Wheel Lip Mouldings
ABC OPTIONS:
F7: Barracuda Formula S Package
H1: Power Brakes
R1: AM Radio
X2: Tinted Windshield Only
abc OPTIONS:
I have a 67 but I think the same holds true for the 68, so here is my best shot at your questions:
How could I have upper door frame color?
Bronze car with a black interior, the metal of the doors was painted black.
There should be a 10 digit number stamped on the trunk lip, driver's side, look under the weatherstrip. The first 2 digits are the year, then the plant the car was made in:
8 = 1968
2 = Hamtramck Assy-Detroit (if it is a 2)
Then next 8 digits will match the last 8 digits on your fender tag.
The first 3 of the 8 will be the build date:
926
The next 5 of the 8 will be the shipping order numbers.
So the 10 digits s/b:
82926xxxxx
The mouldings under the doors, I think.
How do you know for sure the bronze color is incorrect?
Could be, why are you thinking it was not?
I have seen this many times, I think that is original.
I don't think so, wouldn't that mean 9/26/67 for a 68 car?
I'll take that off your hands for you.
Not sure on the woodgrain, but things get changed and replaced over 40 years. The speedo could be either a 120 or 150, so it could be correct as well.
