moparmanestock
Well it has been about a year now, but finally going to get out to Wild Horse tomorrow night. I upgraded the heads and cam. Was only supposed to take a month or two but life puts up roadblocks. So with parts delays and a divorce, not car related, finally hope to get good results.
The upgrade is a set of RHS IndyXs prepped by Brian at IMM, thanks Brian, you did an awesome job on them. The cam is now Comp Mutha Thumpr hyd roller with Hughes 1.6 rockers. Car sounds much crisper now. New lift specs are approximately .570/.555" 243/257 at .050". The compression is also up from around 9:1 to 10.3:1. The old setup is in the 11 second car forum. I am optimistic.
