Badart
Senior Member
http://www.flickr.com/photos/29209642@N00/3786346360/
Finally got the carb and timing close on the basketcase 73 swinger. Pretty happy with the combo so far. Thanks to crackedback I have a power steering coupler on the way so I can run my floor shift column from my parts car.
Here are the specs on the engine and tranny. 318 .040 over flat top pistons .060 in the hole, Comp XE256 cam, Rebuilt magnum heads with 1.6 rockers and chebby behive springs, Magnum dual plane air gap intake, Gear drive, Holley 600, Hooker comp headers. Flowmaster 40 series through 3" exhaust (I plan on running the exhaust in front of the rear tires soon)
I also installed the transgo TF-2 in the 904 and upgraded the torque convertor to a 2,200 stall from mopar performance. B&M Magnum grip shifter. Once I get it driving I will then weld in the 4-link and the narrowed 9" and detroit locker with 3.89 gears and weld in the tubs.
Elk hunting season is around the corner so once I drive it around the block it will get parked in the corner of the garage until the snow flys.
