finished for the season
i took a dome light, an original dart steering wheel center cap, a charger steeering wheel and a center cap i got at a swap meet....and began to hack!
I need some sort of spacer so the cap looked good on the wheel. I had a spare dome light and original dart plastic center cap.
I removed the metal mounting bracket insisde the original center cap and fastened it to the customized dome light housing. I think i used jb weld or two part epoxy.
Once it set up, the center cap from the swap meet fastened perfectly to the mounting ring i took out of the original cap that was glued to the dome light housing. (i was looking all over the garage for something to make a spacer ring out of and the dome light just happened to fit)
picture 1 is the dome light with center cap metal mounting bracket glued inplace.
Picture 2 is the same thing.
Picture 3 is the dome light housing attached to the spacer.
Picture 4 is a dome light.
Picture 5 is the back of the center cap as it came from the factory.
Picture 6 is an example of the 1968 dart center cap i removed the mounting ring from.
i..like it!!
