Firewall bypass
Skeeter007
Skeeter007
Barrie Ontario Canada
So I added an 8 gauge wire directly from the battery to the alternator. So the old wire from the alternator to the firewall and back to the battery is still present. Is this ok or should I take it a step further? I plan on updating the alt to a large capacity to run the stereo. The stereo/amps run directly from the battery with power routed to the trunk for the amps and a direct line to the tape deck. I’m guessing under load the power will take the storage route to the battery on the direct line appose to running through the firewall/ammeter. Should this new direct line be fused? Current alt is 35amp.
Brandon
Follow the build here …..Slow build 71 Scamp 440
You still must check and fix the ammeter/ bulkhead connector, as both the black and red are not the conductors for power from the alternator/ battery, into the pass compartment, for power. When I say "fix ammeter" I mean if you hook them together, the red and black, make sure the eyelets are actually in good shape connected to the wires internally. Signs of heating, melted insulation, etc
Thanks for the reply. Is there a need to do that if everything is good. The reason I ask is I will at some point put the volt meter in the cluster and attach the two wires. But is there a danger to running in my current configuration until then. Also should there be a fuse in line to the battery on my 8 gauge wire. 65 amp alt will be added with the possibility of adding a much larger alt to deal with the stereo that’s going in.
I think it just depends. If you are adding a bunch of stuff like electric fans, big pumps (and coolant), big stereo, etc, then I would for sure get into it. If it is clean and tight, run it
Definitely adding a bunch of stuff. A few old school Orions 2125’s and a sub box and some component speakers. We’ll get a better alt and the bypass done completely before install. So I’ll run it as is till that time. Should be fine.
