Firm Feel UCA's Small Ball Joint pics and review.
Suspension, Steering and Chassis
  1. seabee
    seabee FABO Gold Member FABO Gold Member
    2,488
    657
    Dec 20, 2009
    Bonita, CA
    Local Time:
    2:17 AM
    Hi All
    Just wanted to post some pics and thoughts about the Firm Feel UCA's in case anyone else was looking for them on FABO. I Ordered them on a Friday and received them the next Thursday. I ordered by phone and got an email confirmation and tracking number within a few hours. They came packed very well, almost excessively. They were the "Small Ball Joint UCA's" with the bushings and BJ installed. The cost was $400 and $12 shipping from Washington State to San Diego.
    They are very heavy and sturdy feeling compared to my standard UCA's. The welds look good and the bushings look like the ones I got from my PST poly kit. The ball joint looks like a better quality than standard replacement parts. The big bump stops are a very nice poly material and extra thick.
    They installed flawlessly. There's an instruction in the box that talks about possibly shaving the UCA bushing area, but for mine they cleared. I test drove them and they feel extra firm and have eliminated some of the lean I was getting with my original UCA's with poly kits.
    DO NOT BUY the WSD Ebay UCA's and try to install ball joints and bushings in them. I learned the hard way. That route cost me more $$, time, and almost my life.
    If you want to keep your Drum Brake setup and need a small Bjoint UCA I recommend these.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. Rbob
    Rbob Well-Known Member
    510
    48
    Mar 2, 2009
    Olympia, Washington
    Local Time:
    2:17 AM
    Very nice looking and thanks for the write up.
  3. mopardude318
    mopardude318 Well-Known Member
    10,184
    1801
    Jan 7, 2005
    Gilroy, Ca
    Local Time:
    2:17 AM
    looks good. i have the LBJ ones on my 68 cuda. very nice quality.
  4. Rice Nuker
    Rice Nuker Let the Coal Roll!
    2,262
    72
    Jan 29, 2010
    U.S.A.! Near Jackson CA
    Local Time:
    2:17 AM
    I am buying the FF A-Arm LBJ and T bars for my duster shortly. Thanks for the write up.
  5. 340_dart_power
    340_dart_power Well-Known Member
    1,659
    37
    May 18, 2008
    Middle Tennessee
    Local Time:
    4:17 AM
    Nice writeup on these.
    I just had them rebuild my steering box, and am looking forward to experiencing the difference in handling.
  6. RedFish
    RedFish Well-Known Member
    25,021
    3717
    Sep 5, 2007
    Local Time:
    5:17 AM
    I understand the need for a different bump stop.
    Are they available without the ball joints and bushings ?
    Never mind. I found it. Available but no exactly for sale.
    I've got over 150.00 invested in Moogs offset upper bushings and ball joints.
  7. Gnome
    Gnome Well-Known Member
    545
    5
    Aug 3, 2010
    fredericksburg,va
    Local Time:
    5:17 AM
    it came with a pabst? awesome...lol
  8. C130 Chief
    C130 Chief Mechanical Genius
    3,064
    253
    Nov 23, 2005
    Boise, ID
    Local Time:
    3:17 AM
    And unlike some others out there, these have a nice welded gusset behind the ball joint.
  9. airwoofer
    airwoofer Drivetrain limit explorer
    2,204
    41
    Jan 4, 2011
    Huntsville, AL
    Local Time:
    4:17 AM
    <I test drove them and they feel extra firm and have eliminated a lot of the lean I was getting with my original UCA's with poly kits.>
    Lean... you mean when you turn the wheel left and right and the car seems to just kinda wallow? My 68 fish is that way. Guess it has been too long since I drove an old Mopar and had forgotten how loose cars used to feel. The first thing I did to the hotrod is put new autoparts store front shocks on - they were not as "stiff" as the ones that came off and did nothing for the wallowing. No sawy bars front or rear.
    I would like to improve the handling as I get into this body restore and it looks like UCAs may be on the list.
  10. seabee
    2,488
    657
    Dec 20, 2009
    Bonita, CA
    Local Time:
    2:17 AM
    Yeah, when quickly turning the front would dip down on the opposite wheel a little too much. It still does, just much "firmer" and tighter. I imagine after I get some better shocks (Napa Cheapos on right now) it will get even better.
  11. jerry6
    jerry6 Banned
    2,439
    56
    Aug 29, 2010
    Mon
    Local Time:
    5:17 AM
    Airwoofer
    I have stock UCA and my car has no lean in turns , or wallow , does not feel loose , I have gas shocks , sway bar , 1.0" torsion bar . Poly bushings all around except LCA bushings , those are MOOG .
    If it wallows would look at shocks , lean get sway bar maybe heavier torsion bars , loose/play in steering , check all bushings , the rubber wears and deforms over the years , 1/8" of worn bushings all around adds up to loose feeling in steering , my steering felt loosey goosey , after changing all the bushings I can wait on the Firm Feel stage II steering box , eels 100% better with new bushings .
    Good luck
    Seabee , great write up ! Those UCA are on the buy list when mine need replacing
  12. seabee
    2,488
    657
    Dec 20, 2009
    Bonita, CA
    Local Time:
    2:17 AM
    HAHA! Doesn't everything?
  13. autoxcuda
    autoxcuda Well-Known Member
    7,437
    1716
    Apr 6, 2007
    Local Time:
    2:17 AM
    That's because it is a K7022 Moog upper ball joint. The ones you get in the PST and Just Suspension kits are not Moog.
    The bushing seem to be the same for the cheap kits. But the idler, pitman, and upper and lower ball joints...Go Moog.
  14. jerry6
    jerry6 Banned
    2,439
    56
    Aug 29, 2010
    Mon
    Local Time:
    5:17 AM
    Are you saying the PST and Just Suspension ball joints are NOT good replacements , Moog are the ones to get ? What's wrong with the PST A=ant J S ball joints ?
    Adding this , don't know if it's BS or not
    http://www.cbodydrydock.com/content.php?article.20
  15. 4spdragtop
    4spdragtop CONGRATS NORTH AMERICA! FABO Gold Member
    32,446
    13557
    Aug 28, 2009
    Wasting time here
    Local Time:
    4:17 AM
    Sorry to hijack, but Jerry, I have seen that link here before on this forum and have set in my mind to go with JS for my ball joints unless someone can call bs on this???
  16. jerry6
    jerry6 Banned
    2,439
    56
    Aug 29, 2010
    Mon
    Local Time:
    5:17 AM
    I saw that link and was thinking the same , I want to know if I should buy them or not . There is so much crap comming out of India and China , you just never know
  17. 4spdragtop
    32,446
    13557
    Aug 28, 2009
    Wasting time here
    Local Time:
    4:17 AM
    The 1st time I saw that link was from slantsixdan...very knowledgable guy...but you dont know if its marketing bs or not
  18. JLP
    JLP Well-Known Member
    359
    2
    Apr 25, 2005
    Oregon
    Local Time:
    2:17 AM
    Firm Feel makes nice stuff. Good guys too. I am going to have them make custom swaybars form my 65 dart.
  19. seabee
    2,488
    657
    Dec 20, 2009
    Bonita, CA
    Local Time:
    2:17 AM
    Truer words have never been spoken.
