First fire-up of the 440" W2 Stroker small block
That thing is gonna be awesome in an early A! Please let me know how the set screw works for curing the wet hole issue. I guess valve cover studs might be an option.....
Thanks!
Bloomer Performance Engineering LLC
32210 Redfield Street
Niles , MI 49120
Ph. (574) 340-5470
Fax. (574) 272-0807
360 block
A 340 blocks smaller main would leave you with not much if any journal overlap, especially with a 2" Rod journal
Big shout out to Mike, the MRL lifters are awesome in this motor, I really like the larger diameter .815" rollers and particularly the priority oiling to the axles.
