64physhy
Last night, I went to a cruise night. As soon as I arrived at the "Mopar section", my car died (embarrassing). First, I thought my gas gage was just off, and that I was empty, even though the gage was between 1/8 and 1/4, so I put 5 gallons in it.
Couldn't get it to start still, so, still assuming I had ran out of gas, I assumed that I had sucked the lines dry, so I squirted some gas in the carb. Started up and ran long enough to get me to the top of the hill by my house, then died. This was about 4 or 5 miles from the cruise. I was able to coast it home.
So, today, I blew compressed air through the fuel line toward the tank in case something got sucked in, and changed the filter and pump. I got one of the clear filters so I could see if fuel was getting through.
I've cranked it and cranked it, using gas, starter fluid, etc. It starts until whatever I use burns off, but still not getting fuel flow to the carb.
So, now I'm thinking 1) I have a small hole in the fuel line from the tank; 2) the fuel pick-up in the tank is totally clogged or; 3) The lobe that drives the pump has gone flat.
Any thoughts or suggestions?
