Did you buy specific converter bolts then?
I would also check the mounting holes height as those lugs appear unusually high (by pic).
I make them out of the flexplate to crank bolts. I cut the head down to the 5/16 bolt thickness. If you need them let me know . I also should have an old DC flex plate flexplate . The bolts are $10 to cover shipping and lathe time. This is the second time I am posting this since the start of the thread. It was taken down for some reason.
I wonder why it was taken down. Maybe a moderator had him covered . LOLI saw your original post, for today I am just going to get some bolts to get it all together then worry about some different flex plate bolts.
That flexplate will not work. U can order a 440 source flexplate for $40.00. Get some better tools. Kim
U said u stripped the head on an ARP bolt. So u need better tools. It have to be a lot more careful. Show us the socket that stripped the bolt with. KimThanks! I drilled my stock flex plate to accommodate the 7/16 bolts.
Better tools?
Round off the head of one bolt......one bolt! And now you have an issue with them? Come on! You know how many people use ARP fasteners (studs, nuts, bolts, washers etc) in general and the only way they get messed up is from the installer using a junky tool and/or improper use of the tool. Skip the grade 8 thick headed bolts . Buy the correct bolts for that torque converter.
View attachment 1715904982 View attachment 1715904981
The heads are thin for a reason. Use a quality wrench, not cocked or otherwise on the bolt head. That’s the only reason there was an issue in the first place with your head bolt. User and/or tool issue. Like I’ve said, we’ve all been there. To deny is just being in denial!![]()
That's the problem.Its just a 6pt husky socket. Its brand new, maybe been used 1 time before.
I’m justI am always in denial... like today... I got the transmission in... but not all the way hooked up. So who wins the bet? Im denying that I lost the bet. Lol
you. Talking sockets, if you were to use a socket on a bolt or nut head, and you had your choice of one of these that would ensure good engagement, low risk of rounding off of the fastener, which would be best? And which would possibly cause issues? Which might be more forgiving of user input and which would likely do some damage to the fastener if not careful?You think Husky is a good tool. That's the problem right there.Its just a 6pt husky socket. Its brand new, maybe been used 1 time before.
Neither. KimI’m justyou. Talking sockets, if you were to use a socket on a bolt or nut head, and you had your choice of one of these that would ensure good engagement, low risk of rounding off of the fastener, which would be best? And which would possibly cause issues? Which might be more forgiving of user input and which would likely do some damage to the fastener if not careful?
Bingo!For shallow-head bolts I take a socket and grind/sand down the end so the "teeth" are flush instead of recessed
Agree! Those look like they might be for a midplate application.I would also check the mounting holes height as those lugs appear unusually high (by pic).
Let’s keep things in perspective here. Any will work but you have to pay extra attention when using certainly the tapered 6-point.Neither. Kim
