flexplate to crank question
orangecrush
How long are these 6 bolts and can I use grade 8's from the hardware store ? I've seen Mopar kits from Summit for all 6 bolts plus the 4 torque convertor bolts for around thirty bucks - this may be my best route sincethe convertor bolts I won't find anywhere ....
The flex plate to crank bolts are special length and head size also.
Application correct would be the best route.
Regardless where you buy them be sure to check the bolt length compared to flex plate thickness, etc.. Bolts too long can damage the converter.
