Float bowl gasket
Sussmad
Can you buy these separate or do you need to buy the entire kit? Holley 1920 I think I am working with a '73 carb.
you can get a bowl gasket at napa. you'll probably have to order it.
went through nightmares with mine, be sure to get the GOOD sealer, too, but before you seal that puppy in make sure you've got your float adjusted properly, etc.
