Floor pans and trunk
Chuckman
Virginia
What should I coat my floorpans and trunk with on the inside? I'm considering using a spray in bed liner like Line-ex.
Thanks,
Chuck
I like the idea of the rubberized bed liner, such as that from Dupli-Color. It seems to remain flexible much longer than what Chrysler used 50 years ago. Some guys have used it wherever undercoating would be sprayed and it tends to deaden sound. But, I believe the Dupli-Color product is brush-on.
Tremclad.
Quick, easy, and cheap. It'll last the life of the car.
Dynomat on top of that if you want noise and heat reduction.
I used Lizard Skin on my buddys mustang I have to say it worked very well and 5 gallons only weighs 8lbs
I use that spray on bedliner for the frame & floors top & bottom on just about every car I did work to its tough & looks good
Rustoleum gallon bedliner. Wal-fart has the best price; Then some home depot HVAC sound deadener that covers at least 30% of the panel.
