[SOLD] FLOOR SHIFTER and STEERING COLUMN $175
cudavert
DARTAHOLIC
Hesperia, CA
I've had these parts for over 2 decades, and I'm pretty sure I won't be needing them. I believe the floor shifter setup to be complete (correct me if it is not). Notice that the rubber floor boot is intact and uncracked with original screws. The red column isn't perfect, that's for sure.....needs the bottom piece installed where it attaches to the steering box. It is not included, I don't have it. I am not even sure if this is for a manual or power steering car. I was very careful when I removed the welded shifter from the floor, as best as I could. $175
Was told it came out of a '67 barracuda. As I mentioned in the text, I am not sure if it's from a P/S or manual car.
That's a 67 power steering floor shift column. They don't work well with a big block due to the large bearing retainer at the firewall end.
