FlowKooler or Milodon water pump
Heating / Cooling / AC
  1. 68 Coronet RT
    68 Coronet RT 68 GTS # 508 in Registry
    239
    35
    Nov 5, 2015
    Upstate New York
    Local Time:
    12:30 AM
    Has anyone used either one of these water pumps on their small block ? Just wondering if one is better than the other
  2. MOPAROFFICIAL
    MOPAROFFICIAL Well-Known Member
    2,928
    1928
    Jun 1, 2016
    breakwater
    Local Time:
    9:30 PM
    Probably close to the same. But check their sites for specs.
    Really...those are designed to fix or anticipate a couple issues or weak points..like very high rpm cavitation, extra volume, maybe a better bearing.
    Stock 8 blade impeller is more than enough when the cooling system is properly sized and holding pressure.
    • Agree Agree x 2
    • Like Like x 1
    • QuickDart360
      QuickDart360 Well-Known Member
      751
      200
      Apr 5, 2014
      San Antonio
      Local Time:
      11:30 PM
      I currently use an 8 blade mopar performance unit. So far works great.
      • Like Like x 2
      • dgibby
        dgibby Well-Known Member
        920
        325
        Aug 23, 2012
        utah
        Local Time:
        10:30 PM
        I just bought one of these but haven’t run it yet. Water Pump PRW Industries 1431800 - Pace Performance Parts
        It for sure looks superior to what I took off. Was told the one I took off was a high flow but don’t know for sure. It’s an 8 blade with no anticavatation plate on it and at higher rpms my temp would creep up. I got real lucky on the PRW, found it on eBay for $67 bucks and 15% off. Figured for that money it was worth the risk. It’s the exact same as the Edelbrock version that is big bucks.
        I thought I read somewhere that the PRW is better at higher rpm and the flow cooler is better at low speed, stop and go driving. I also went with this thermostat in this post I started and would probably swap it before the water pump and see what happens.
        Thermostat comparison
        • Like Like x 2
        • rustycowll69
          rustycowll69 Well-Known Member
          1,692
          648
          Feb 19, 2016
          Pacific northwest
          Local Time:
          9:30 PM
          I've installed both, at the request of customers, and I didn't see any difference in operation. They were chosen perhaps more for prevention, rather than to address an evident/ongoing problem, so there was no noticeable "improvement".
          • Like Like x 2
          • 68 Coronet RT
            239
            35
            Nov 5, 2015
            Upstate New York
            Local Time:
            12:30 AM
            I looked at the PRW water pumps and they don't make one for early LA engines with the bottom hose on the driver side
          • Gamedog
            Gamedog Well-Known Member
            475
            471
            Jul 10, 2016
            Parker, CO
            Local Time:
            9:30 PM
            I've got the Milodon high flow on my 408 and it performs as it is intended to.
            • Agree Agree x 1
            • 66340SEDAN
              66340SEDAN FABO Member #3649 FABO Gold Member
              25,702
              10479
              Nov 20, 2006
              Minnesota
              Local Time:
              11:30 PM
              I use a Flowkooler on my 340’s....one didn’t last long, about 5 years or so but my car never ran hot...never had cooling issues, just figured it would help to have it.
            • BrianT
              BrianT Let's go! FABO Gold Member
              5,312
              888
              Mar 13, 2007
              Kansas City, Mo
              Local Time:
              11:30 PM
              X2
            • supertruck
              supertruck Retired Old Fart stock car racer FABO Gold Member
              394
              164
              Feb 14, 2016
              Gloucester, Va
              Local Time:
              12:30 AM
              I installed a Flowkooler on the 429 SCJ in my Cobra replica, about 10 years ago. operation has been flawless.
            • whit68
              whit68 Well-Known Member
              67
              16
              Jan 22, 2013
              Perth
              Local Time:
              1:30 PM
              X 3
