this is a 1960's engine! do not run 5-30 in it... dont go any lower than 10-30... 10-40 if it uses a bit of oil...
run something with Zddp in it... i like Valvoline VR1 as you can get it at ANY parts store on the shelf...
and its 4.5qts including filter...
on the trans how long since it was last serviced? is the fluid really bad? if it is then i might not even change it as it can kill the trans... but if the fluid is ok +3 or +4 is good...
ZDDP for short is Zinc. zinc adds a protection barrier between the camshaft and lifter without it it will aid in wiping out the camshaft lobes. Roller cam do not have this problem but flat tappets do. I second on the VR1 oil because it contains ZDDP. I would run DEX III in the transmission. You may only find it as Dex/Merc though and is the same thing.
I will go get the Valvoline VR1 then. I just want to do the right thing.
I use to use Dex3 in my Bronco. SO I know what to get then. I sold my Bronco, and went Mopar.
I see the filter is "face down". Do they sale a filter that will sort of hold the oil, so no dry starts, or am I being paranoid?
Also!! I used the word tappets one day, and a kid at the parts store looked at me odd. He didn't know what I was saying...
You know more about this **** than a 21 year old.
Did you have a previous life as a car mechanic???![]()
i thought dex III was ford... i would look for
ATF+3 which is mopar fluid...
lol i just try to pay attention!
FYI, Quaker State has a new oil called DEFY for older cars with flat tappet cams. Found it at Wal Mart.Quaker State's jab at the government "DEFY"
Wooooo, I have to look for that! Good find! Does it say "Defy" on it for real?
I looked for the Valvoline VR1, I can't find it? :banghead:
I can't even find the trans fluid, everything I saw with a +3 or 4 said synthetic.
