[Found!] Flywheel and bellhousing for 318 (for engine test stand)
Trevor B
Novato, CA
Don't have to be pretty or in perfect shape, just have to fit! They're not for installation, just to go on the test stand engine.
If in Chicago or San Francisco Bay Area, or anywhere in between near Hwy 80 on July 14th or 15th I'd love to come pick up parts.
Thanks!
could you do a convertor on a flex plate too? Thinking along the same lines....Much cheaper finding a junk convertor than a flywheel.
I thought about that but doesn't it seem kind of heavy and less balanced without something for the converter to spin on? Or maybe saw a junk converter in half to just use the ring gear half?
I didn't look, seems to me someone was marketing a flywheel with removable weight for internal/ external balance engines.
You don't exactly REALLY NEED a bell. You could fab a plate to mount to the bell surface, and to mount the starter. Sort of like "part of" the engine plate for a scattershield
Still need a small block bellhousing that will take a 10.5" clutch... the one I found was for a truck and takes a bigger flywheel than I have!
I have one in Indiana if you want to ship that far.
