Ford 8.8 shock plates?
Garethw
Mopar. Because rocket science is too easy.
Georgia
When I grabbed a Ford 8.8 from the junkyard I took the shock plates too. They came from an Explorer. Any reason I couldn’t use these in my 65 Valiant?
Yeah, I guess it’s angled compared to the original.
3" axle tube. You will have to file the holes out for the wider 8.8 ford U bolts. U bolt nuts may hit the flanges. Try em. Looks like they are $40 per side, and then you have to get the shock studs.
I’ve got time to look for another solution. Won’t be ready to stuff this in the car for a little while.
What’s the spacing between the mounting holes on that 434 model?
