jimrat
You can use off set wheels but it will look funny because the off set is maxed outward, if your sister is driving it a 8 1/4 would do fine you will have to reweld spring plates and set your pinion angle 0-2 degrees. You will also have to install a different poportioning valve, and drive shaft fitting so no peice of cake but worth it for me as I do all my own work and search out recycle yards for parts.AdamR said:Did you narrow the rim for a certain rim/tire combo or is it to long as/is to use ?
