Formula s wiring
bamacuda
Hoover, Alabama
Are there any differences in the under dash wiring harnesses for a 65 barracuda vs. a formula s other than the tach? If I have a tach and sending unit, can it be added to an existing 65 under dash wring harness?
The tach should get its 12 volts from the fuse box. You could tap the 12 volt supply to the inst' panel but... that line isn't fused. If I didn't have accessory fuse slot available I would get 12 volts form the load end of the turn signal fuse.
There are a number of blades on the backside of the fusebox to tap your 12V from, thats where the factory got it from!! Geof
